YJ Bj 1994 Check Engine?
Diskutiere YJ Bj 1994 Check Engine? im JEEP Wrangler YJ Forum im Bereich Wrangler; kann mir jemand sagen was das sein kann? keine ahnung ob ich den auslesen kann... danke im voraus
  1. #1 delonge, 20.06.2013
    delonge
    delonge Newbie
    longer
    danke im voraus
  2. #2 delonge, 20.06.2013
    delonge
    delonge Newbie
    longer
    hab was gefunden und werde euch dies nicht vorenthalten:
    Just thought this should be included on wranglerboard!
    This applies to Jeeps with On Board Diagnostics 1 (1991-1995 in YJs)
    First, if you do not have a DRBII scanner you can easily do the "key trick." The on-board reporting will communicate trouble codes to you through the check engine light in a series of flashes; similar to Morse Code.
    The key trick: With the ignition OFF, turn the key to ON (do not start the jeep), OFF, ON, OFF, ON (Complete this sequence in under 5 seconds). Be sure to leave the key in the on position until the END OF CODES sequence has flashed (55)
    Once the Check Engine Light has turned off, it will pause in the off position for a second or two, and then start to flash, count the flashes. Each code stored will be given to you in a 2 digit sequence. As an example, code 43 would be FLASH FLASH FLASH FLASH... <PAUSE>... FLASH FLASH FLASH followed by a <LONG PAUSE>, followed by the next code. There will never be more than 9 flashes without a pause, and finally Code 55 signals the end of stored codes. Repeat the key trick if you were unsure of a code.
    Quick Note: Code 12 is a very common code, and indicates the battery has been disconnected within the last 50 startups. Code 33 will always be present for jeeps without air conditioning. Neither of these codes will themselves cause a check engine light to be displayed.
    List of codes/standard meanings:
    11: No ignition reference signal detected during cranking (bad hall effect) OR timing belt skipped one or more teeth; or intermittent loss of either camshaft or crankshaft position sensor
    12: Memory Standby power lost (Battery or computer recently disconnected)
    13: No change in Manifold Absolute Pressure sensor (MAP) from start to run
    14: MAP sensor circuit open or shorted; voltage too low
    15: No speed/distance sensor signal
    16: Loss of battery voltage detected with engine running
    17: Engine stays cold too long (bad thermostat)
    21: Oxygen sensor signal out of range, possibly shorted
    22: Coolant sensor signal out of range (or disconnected to set timing)
    23: Intake air temperature signal out of range
    24: Throttle position circuit out of range
    25: Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached, vacuum leak found
    26: Peak injector circuit voltage has not been reached
    27: Logic module fuel circuit internal problem or TBI injector does not respond properly to control signal
    31: Evaporator Purge solenoid circuit open or shorted or Evaporator solenoid circuit
    32: EGR system failure or Power loss lamp open or shorted
    33: Air conditioning clutch relay circuit open or shorted ( Also will show up for rigs without AC)
    34: Speed control vacuum or vent solenoid circuits open or shorted
    35: Cooling fan relay circuit open or shorted
    36: Wastegate control circuit open or shorted
    37: Shift indicator light failure, 5-speed (blown bulb) OR Park/neutral switch failure OR Torque converter unlock circuit open or shorted, A-413 4-speed auto
    41: Alternator field control circuit open or shorted
    42: Automatic shutdown relay circuit open or shorted
    42: Fuel pump relay control circuit
    42: Fuel level unit - no change over miles OR Z1 voltage missing when auto shut-down circuit energized
    43: Peak primary coil current not achieved with max dwell time OR Cylinder misfire
    43: Problem in power module to logic module interface
    44: No FJ2 voltage present at logic board OR Logic module self-diagnostics indicate problem OR Battery temperature out of range
    45: Turbo boost limit exceeded (engine was shut down by logic module)
    46: Battery voltage too high during charging or charging system voltage too low
    47: Battery voltage too low and alternator output too low
    51: Oxygen sensor stuck at lean position OR Internal logic module fault ('84 turbo only)
    52: Oxygen sensor stuck at rich position OR Internal logic module fault ('84 turbo only)
    53: Logic module internal problem
    54: No sync pickup signal during engine rotation (turbo only) OR Internal logic module fault ('84 turbo only)
    55: End of codes
    61: "Baro" sensor open or shorted
    62: EMR mileage cannot be stored in EEPROM
    62: PCM failure SRI mile not stored
    63: Controller cannot write to EEPROM
    64: Catalytic converter efficiency failure
    65: Power steering switch failure
    ________________
    quelle wranglerboard
  3. #3 diseption, 20.06.2013
    diseption
    diseption Jeeper
    Justus
    jo, wird auch hier im Forum schon beschrieben. Sogar auf Deutsch ;-)
    Was sagt deiner denn wenn du ihn über den Schlüssel ausliest?
Thema: YJ Bj 1994 Check Engine?
  1. YJ BJ IM
