Das hat mich auch interessiert - jetzt weiß ich`s - ein Suzhou Bakus GKT400L Beim googeln hab ich das hier gefunden: Description: 400cc Go Cart Specification 1)Dimension----------------------------------------101.6*62.2*59.1(inch) 2)Wheel base-------------------------------------- 76.8(inch) 3)Total Weight--------------------------------------- 880(pound) 4)Max.speed-------------------------------------- 52.2(m/h) 5)Front shock travel----------------- 17.7 (inch) 6)Rear shock travel ------------------- 16.9(inch) 7)Front and Rear Independent suspensions 8)Two passengers 9)Front rim---------25x8-12/12x6 10)Rear rim--------25x10-12/12x8 11)Hydraulic Disc Brake 12)Ground clearance-------------------------------13(inch) 13)Capability of fuel tank------------------------------5.3(gal.) 14)Two wheel drive ENGINE Engine Type ------------------------------------------single cylinder, four stroke ,strong wind and oil cool Cylinder diameter ------------------------------ ---- 3.3(inch) Piston run distance ------------------------------------2.8(inch) Cylinder capacity:-------------------------------------- 0.1(gal.) Ignition----------------------------------------- ---------- DC-CDI Five speed clutchless trnsmission with reverse No paddle Electric and pull start Main clutch---------------------------------------------- ungula acentric automatic-clutch Auxiliary clutch----------------------------------------- clumpy drive clutch Standard power---------------------------------------- 21.76 HP Max Power------------------------------------ --------- 23.12 HP Max Torque--------------------------------------------- 20 ( pound/m) Fuel consume ------------------------------- ?ܰ.78(pound)/km/h Idle speed ---------------------------------- 1500r/min Compression rate-------------------------------------- 8.6:1 Transmission rate------------------------------------- primary 3.167, the first gear 3.333; the second gear 1.889; the third gear 1.364; the fourth gear 0.962;the fifth gear 0.704. Fuel-------------------------------------------------------- Unleaded 90 -Petrol Hier gibts noch mehr: KLICK Grüße Andreas
hir wird geschraubt ... .... auch wenn der platz nicht reicht und es weit und breit kein strom gibt ... ohne füllung ... mit füllung ... ich beneide jeder der ne ordentliche schraubergarage hat oder noch besser sogar ne hebebühne ...
