Erstmal vorsichtig das in Englisch sage, denn die meisten verstehen es ja kann es aber auch gerne uebersetzen! Just ordered a super-hot ignition coil "Screaming Demon" and awesome 10mm wires to go with it! A friend who is using this set-up reports "only good stuff", incl. a 1 MPG increase. That will get better, but for now he can't keep his foot out of it, running strong! Hope it will do the same for me! If nothing else, it will waterproof the ignition a lot more, because the silicone boots grabb like crazy. They withstand heat up to 1,400 F!Anybody running this set-up?http://www.sor7.com/JEEP-Accs.html(Scroll down)
