Frankreich - Wald + Forstwege -
Diskutiere Frankreich - Wald + Forstwege - im Smalltalk Forum im Bereich Allgemeines; Ich habe Regelungen über das befahren von Wald und Forstwege in Frankreich gefunden. - Leider nur in Ausländisch.- Da muß es irgendwann mal...
  1. Raptor
    Raptor Guest
    Da muß es irgendwann mal Aufruhr mit den Geländewagenklubs gegeben haben.:keule:
    :vertrag Dies soll die geltende Regelung sein.
    Wenn es jemand Übersetzen möchte, wäre vielleicht interessant.
    I read the site Codever.fr (an association of off-road drivers) and it seems that they are very happy because the law has changed : the "loi Olin" is no more applicable
    What is forbidden is the "hors-piste" which means you can not go where there is no "road"
    >Woody wrote....
    > - What I understand is, that ways:
    > - which are drivable with a 4x4,
    > - not marked as forbidden,
    > - not closed by a barrier or
    > - located in a national park
    > - not privatly owned
    > .....are allowed to drive
    it's correct - i try to translate the codever resume
    - Only the "off piste" is strictly prohibited. Motor vehicles can move freely on the roads and "small roads" open to public traffic;
    - Rural roads are unconditionally authoised to public traffic of motor vehicles, unless specific local regulations;
    - Private owners are only to decide whether or not open to public traffic of motor vehicles their private roads or exploitation. The Department recommends that decision formally to materialize on the ground, to avoid ambiguity and any dispute;
    - The sworn officers will primarily look for offenses characterized: outstanding off-road and traffic routes clearly marked as prohibited.
    what does not change :
    The following locations do not become traffic lanes. Avoid them
    - The paths clear for hiking because of their small size (Ed: unless of course these are rural roads: to check beforehand on the register);
    - Ephemeral plots (skid trails open and used by tractors only for the duration of the operation of a cup, for the sole purpose to draw the wood);
    - Bands firewall set up in the forests to prevent the spread of fires;
    - Clandestine routes, by dint of repeated passages, create a track on the ground while the owner was never the intention to create such a path in this location;
    - Rights of way without trees due to the presence of underground or aerial (pipelines, power lines ...), environmental cover (grass strips ...), or open to separate forest plots (lines partitioning).
    i hope that i will help you understand a little more
  2. #2 grimaldur, 01.02.2012
    grimaldur
    grimaldur BROTHERHOOD
    Jean-Philippe
    das hättest du besser auf französich gepostet :cool
    aber grob gesagt.. die "circulaire Olin" ist für ungültig erklärt worden.
    das heißt:
    - nur der "hors piste" ist strikt verboten (also da wo keine wege sind)
    - feldwege sind weiterhin erlaubt (ausser es gibt ein lokales verbot)
    - private wege, sind erlaubt, ausser der eigentümer verbietet dies (muß er aber kenntlich machen)
    - die gesetzeshüter müssen sich auf "hors piste" und klar ausgeschriebene verbotene wege konzentrieren.
    was sich nicht ändert: VERBOTEN IST:
    - fußgänger wege (nicht so breit das ein auto durchkommt)
    - wege die für den abbau von holz "temporär" erstellt sind.
    - feuerschutz wege (also wo eine freie fläche im wald ist.. als feuer bremse..
    - wild erstellte wege (weil da einfach viele durch sind, obwohl der eigentümer nie einen weg da machen wollte)
    - freie flächen, die da sind weil untererdisch gebaut wurde, parzellen trennung usw..
    also..
    -auf die wegen bleiben!
    -weg muß breit genug sein für das auto
    -kein verbotsschild
    dann darf man fahren.
  3. #3 simplydynamic, 02.02.2012
    simplydynamic
    simplydynamic Master
    Ich finde da wir alle EU sind, sollten wir das hier auch anwenden..... :pfeiffen
    Werd ich bei der nächsten kontrolle mal sagen/vorzeigen. Dann sag ich das ist ne EU Regelung und nehm den französischen Zettel mit :-)
  4. Raptor
    Raptor Guest
    Danke Jean-Philippe für die Übersetzung. :daumen
    Ich wollte es in Französisch einstellen aber ich habe es nur in Englisch übersetzt gefunden.
  5. Raptor
    Raptor Guest
    Wenn du das in D vorzeigst, hast du den Beamtenaparat gegen dich.
    Und dein Schiksal nimt seinen Lauf. :rolleyes:
  6. #6 grimaldur, 04.02.2012
    grimaldur
    Jean-Philippe
    wenn dann belege auch den zettel.. mit eine landkarte..
    am besten eine besetzungslandkarte.. von 1920 oder 1946..
    wo klar drin steht.. das du in Frankreich bist :happy:happy
Thema: Frankreich - Wald + Forstwege -
  1. feldwege in frankreich
